跳转到主内容
宏碁所制造的台式机的维修和支持指南。
51 个问题 查看全部
Locked out of desktop
Locked out can't remember I'd or password
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
评论:
I cannot get into the system. I've tried f2. F12. Delete. On start up. Won't let me into the bios
完成的
添加一条评论
1个回答
Hello Nate! The only way to bypass your Windows password (that I know of) is by using a tool called "Konboot". You need to buy a license if your Windows version is new than XP. The program is installed on a USB stick. Once it is installed, you boot from the USB stick and Konboot will do its magic and take you straight to Windows where you can put anything in the password field and it will work.
If you do not mind losing your data, you could try doing a system recovery.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Nate Grieve 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 1
过去的30天: 1
总计 92
