跳转到主内容
The Galaxy 551 is a slate-form/QWERTY Android smartphone released by Samsung in 2010. Identifiable by model number GT-i5510.
10 个问题 查看全部
transfering photos to a computer
How to transfer photos to computer?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
4个回答
最有帮助的答案
Download the Google photos app. Select free high quality storage in the setup. When you're all done, go to https://photos.google.com to access the photos on your PC.
这个答案有帮助吗?
得分 5
添加一条评论
http://support.bell.ca/Mobility/Smartpho...
That will show you how to do it.
Hope this answered your question, if it did please hit the accept answer button!
这个答案有帮助吗?
得分 2
添加一条评论
The most common way to transfer photos between Android phone and computer is to copy and paste the files. This method can be completed with one USB cable easily. You just need to establish a connection between your Android phone and computer and once the computer detect your phone, you will be able to move the files from/to computer without any hassle. The details are:
Step 1. Use a USB cable to link your phone to computer. During the connection, you need to enable USB debugging on your phone to make the device be detected.
Step 2. After the detection, you can double click on the icon of This Computer on your PC and then find out your phone.
Step 3. Now you can double click on your device to open it and then click on the folder named DCIM.
Step 4. In this folder, you will see the Camera folder and you should double click on it. Then you see all the images that you have saved on your phone.
Step 5. Now if you want to move the photos from Android phone to computer, you can select the wanted files in the Camera folder and right click to choose Copy option and paste them into your computer. But if you want to sync the images from computer to the mobile phone, you can choose and copy the files from your computer and then paste them to the Camera folder.
这个答案有帮助吗?
得分 0
添加一条评论
An option is to move the pictures via Google Drive. As long as you connect your device to a stable network, you can upload files to the Google Drive easily and then download them onto your Android phone or computer anytime and anywhere you like.
The methods mentioned above are doubtlessly able to transfer photos between Android phone and computer but you can perform the moving process more effortlessly- make use of a professional assistant software. And here I want to recommend this one for all you Android users: MobiKin Assistant for Android (Windows & Mac).
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
thomas22tbj 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 59
