跳转到主内容
修复你的物品
维修的权力
配件 & 工具
sylvania 32 watt octron 4100k
I have overhead kitchen lighting that takes 4 -1 inch by 4 foot of these bulbs. I replaced the bulbs but the lights won't turn back in. Breakers are all good. Any idea why they won't work ? The last bulb burnt out and was working. I replaced all 4 and they won't turn on. Help
已回答! View the answer 我也有这个问题
这是一个好问题吗?
得分 0
评论:
@mizart2u if you can let us know what model your light is and post some images of the light as well as the description marked on the old and new bulbs. Use this guide to add images 在已经存在的问题里加入图片
完成的
添加一条评论
任天堂 Switch 套装
快速恢复到游戏的状态
购买 Switch 套装
任天堂 Switch 套装
快速恢复到游戏的状态
购买 Switch 套装
1个回答
已选择的解决方案
@mizart2u , Steve W, ensure you installed the correct bulbs for the fixture if indeed T8 fixture, T8 bulbs should be used. Make sure the bulbs had no protective end covers/plastic on them and are inserted properly. Check for power at the fixture with DVOM or non contact electrical tester, if no power switch or breaker could be bad. If you have power, correct bulbs and properly installed, either there is a bad connection to/from ballast or ballast is bad. Links below may help. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
https://www.homerepairtutor.com/fix-your...
http://ask-the-electrician.com/fluoresce...
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Steve W 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 1
过去的30天: 2
总计 323
