跳转到主内容
Nintendo's first 3DS handheld device released February 2011, identified by model number CTR-001.
455 个问题 查看全部
Safehax is giving me a black screen?
Okay so my 3d's won't work without a SD card with out all the files downloaded from 3ds.guide so now I'm just like f- it why not just do it again. The thing is now safehax just giving me a black screen. What's wrong with it? What can I do to fix it?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
最有帮助的答案
You need to follow the guide very carefully. It had a warning to NOT to close the screen. If you do that, the system will go to sleep mode. I see that you're installing custom firmware on it, so if you did close the screen during this process, it probably bricked. Once this happens, there's no way out except for sending it out to Nintendo.
这个答案有帮助吗?
得分 1
添加一条评论
The only other answer here says that you may have bricked it by closing the lid. Unless you were on the 2.1.0 downgrade step, this is rather unlikely, at least from what I can tell.
You probably wanna ask that question to the good folks at GBATemp what the issue is, as they're likely to know.
Here's the link to their "Noob Paradise" thread, where you can ask them.
Unless you get a bootrom error, I would highly advise not sending Nintendo your 3DS if you have hax on it.
Hope that helps you any, despite being late.
-Pyra
这个答案有帮助吗?
得分 0
添加一条评论
Everyone else here is incorrect, you can only brick new 3ds by closing the lid. If you have another sd, try putting all the files on it (new downloads so they are for sure working) and then booting again. That should work. You can also look at the troubleshooting on Plialect's guide.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Bumbum Boop 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 939
