Why is the computer running slower each time I use it?
Each time I start up the computer again, it feels like it runs slower than the last time I used it. I already tried updating the software, but that didn't fix the problem.
Sometimes the computer can run slower when there are unnecessary apps that run in the background when you start it up. If you've already tried updating your software, I would recommend downloading and running a spyware program. This will help if you have a virus that is causing your computer to slow down. If this doesn't help, feel free to check out the troubleshooting guide here.
这个答案有帮助吗?
When computers slow down its usually from spyware or malware Run a trusted anti spyware program like "Spybot search and destroy" or Malwarebytes
Hope this helps
这个答案有帮助吗?
On a Mac i would do a "Force Quit" to close programs running in the background. But I don't do Windows, so I really don't know if this can be done on a PC.
@nikob997 , download ccleaner from piriform.com -- it should clean out gunk buildup.
@mayer, the quickest way on a Mac is to boot in to Safe mode and reboot out of it. This flushes stale cache, frees sometimes up to 3gb, and rebuilds cache.
@avanteguarde Well this question is not about a Mac. Also rebooting is not quick and doing a force quit actually tells you what is running in the back ground] so you can get rid of unwanted programs starting up in the background. Some can be found in System preferences > Users > log in BUT as I stated this is on a Mac and the OP asked about a PC!
@mayer ,
On a PC you can open Task Manager to see what applications and services are running.
With services you can see which ones are utilizing most of the resources e.g. CPU time, memory etc.
You have to be careful when closing services as you have to know their function. They might be system services and turning them off could mean that the PC stops responding. Fortunately you are usually 'asked' if you are sure that you want to do this so you get another chance to stop doing it if you aren't sure.
Another check is to open Task manager and view Startup tab. This lists all the applications that are started when the PC first boots up. A lot of programs install auto update applications in Startup so that it slows the PC as they are all trying to check for updates. I usually disable them and do manual update checks on the programs but can appreciate that most people prefer the auto update feature of programs as it is less to have to think about. ;-)
I find that using IOBIT's Advance System Care (Free version http://www.iobit.com/en/index.php ) fixes the problem and helps keep it clean, as well as it has a very great device driver updater, un-installer and, malware protection too. If you decide to buy it, it's currently on sale, I use the Pro-Version.
这个答案有帮助吗?
@jwmurphy I will take a look at it when I have the chance. Interesting looking Mac software. Thanks!
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 696
