跳转到主内容
修复你的物品
维修的权力
商店
The Nintendo 2DS is a handheld gaming device developed as an entry level version of the Nintendo 3DS with nearly identical hardware, but without the 3D upper screen function.
156 个问题 查看全部
SD Card Stuck In Write-Protection (Console Problem)
Hello,
i am having a problem with the console saying the SD card is stuck in write-protection. i can tell you for a fact, the card is not. the slide is at the top and have even tried 2 other SD cards. The other SD cards i have also work fine in another 2DS i have tried.
are there any suggestions how how to fix it? i updated the console and formatted it just to see if that would fix it.
Thanks
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个回答
最有帮助的答案
Try to open up and clean the contact pins, they could be dirty and shorting something out.
这个答案有帮助吗?
得分 3
评论:
Thanks for the reply, i gave it a shot but to no prevail. nothing is screaming out at me that there is anything wrong visually
完成的
What about the 2 smaller pins to the side?
完成的
they appear to be fine, not touching each other
完成的
What about cleaning around the connector? Also has it ever been water damaged?
完成的
yeah ive cleaned it. it was all clean already but gave a clean as best i could just in case. there is no liquid inside. no visible sign of water damage
完成的
添加一条评论
添加你的答案
James 将永远感激不已
浏览统计数据:
过去的24小时: 2
过去的7天: 7
过去的30天: 25
总计 2,489
