跳转到主内容
The Alcatel OneTouch Pop Icon is a smartphone with an Android operating system. The release date for the Pop Icon was October 2014. Model number: A564C.
50 个问题 查看全部
My Data won't work
My wifi works perfectly, but when I turn off my wifi and turn on the data connection my phone still says no internet connection, and yes I do have data. I need help BAD.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
1条评论
Same problem
完成的
添加一条评论
4个答案
最有帮助的答案
Hi @dipblomatt ,
Can you send and receive MMS texts OK? (texts with pictures or videos)
If so, it proves that your mobile phone data connection is working OK. (MMS require the data connection to be enabled and working, SMS use a different protocol and don't require the data connection)
You may be having a problem with the browser app that you are using.
Here is a link that may be of some help
这个答案有帮助吗?
得分 1
添加一条评论
just check your apn setting and make sure your using the correct apn of your network provider
这个答案有帮助吗?
得分 0
添加一条评论
It won't come back on
这个答案有帮助吗?
得分 0
添加一条评论
I did double-check my network mode. I was in CDMA. I needed to be in LTE/CDMA.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Lloyd Luttrell Sr 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 5
总计 5,850
