I can't put my battery in correctly
My phone froze after a update so I removed the battery and put it back in and now one of the sides are crooked and I can't put it back
hello, you could tap it into place with a hammer, it worked for me after i found a samsung S4 on the side of the road when i was walking one day
sadly though the back case was missing
这个答案有帮助吗?
The bottom side of the battery is sticking out though
Tap it with a hammer! Do you want it to explode!
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 55
And it won't turn on
由 minecraft killer55 完成的
What do you mean? Add some pictures to the question.
由 George A. 完成的
Hi ,
Did you put it back in the correct way?
更换三星盖乐世S5的电池
Also not sure when you say "....put it back in and now one of the sides are crooked and I can't put it back"
You "put it back in and now you can't put it back" doesn't make sense
由 jayeff 完成的
Hi,
Does the battery look 'swollen'?
Did you have any problems removing it from the phone?
You might have to compare it to a new compatible battery to see if it is distorted in any way.
由 jayeff 完成的
