跳转到主内容
各种形状、大小和颜色的PC笔记本电脑的维修指南和拆卸信息。
18819 个问题 查看全部
Is 50°c normal for a laptop hard drive?
My laptop has been running hot, and I noticed that the hard drive was running at 50°+. My desktop's hard drive never hits 30°, but of course it isn't the main drive, and it has good cooling. Thanks!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
2个答案
已选择的解决方案
@pccheese, George A. I was curious about this also, so I checked out quite a few forums and they were all pretty close to the same conclusion on HD ideal and safe operating ranges. Look's like yours may be running on the high side of acceptable. Maybe also look up your particular HD and it may have actual heat range specification. Found this info. at the link below which you should check out as it is fairly informative, talks about failure rates, etc..
What is a Safe Hard Disk Temperature Range?
Drawing conclusions from the Google paper, smaller independent studies and tech forum users:
Less than 25°C: Too cold
25°C to 40°C: Ideal
41°C to 50°C: Acceptable
More than 50°C: Too hot
Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
http://www.buildcomputers.net/hdd-temper...
这个答案有帮助吗?
得分 4
3条评论:
Well... I guess I'll have to find some really thin heatsinks. Or something else.
完成的
P.S. I press the "helpful" button whenever I see a post of yours. I don't need to read it to know it's helpful.
完成的
@pccheese, Thanks George, perhaps a cooling pad.
完成的
添加一条评论
Found the issue. In the BIOS I had the HDD setting set to "High-performance". I'm not positive but I believe this is a slight overclock in timing for the hard drive so the motor will spin faster and increases voltage too. After I turned it off it ran cool as it should.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
George A. 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 139
