How much would it cost to fix the rare passenger tire that got bent
is it worth me fixing the rare tied after it got hit n got bent n to fix it is coming out of my pocket n what parts u think it would need to get it atless in running conditiond
Daisy Abarca , A good replacement tire and rim can be purchased from a good local auto recycling/wrecking yard $25-$75.00 depending on rim type(aluminum). But that is not the big concern here, if you hit something hard enough to bend the rim there may be hidden damage eg. damaged hub/bearing,rear axle,strut,sway bar,links,etc.. All this should be checked out for (safety) and driveability. The labor rates are usually a lot less at a good local body shop then Dealer or mechanics shop and deal with this type of occurrence all the time, if able have a technician take a look, diagnose and estimate repair. As stated before all parts can be good salvaged parts, at a fraction of cost of new. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
这个答案有帮助吗?
yes thanks this was really helpful cuz they did a hit n run on it n it was hard enough to bend the rim and much more so ill do that n take it to a body shop n see if its even worth fixing it thanks ones again
Daisy Abarca, Thanks for replying back, I hope your car will come out OK and that they can keep the expense down.
Get it to a local tire shop, honda dealer, or mechanic. They can give you estimates on what it will cost to repair. Tire shops are probably best as its a tire thats at fault. You would need a new tire, rim the tire put on, an alignment, and other things. So just take it to one of those places so they can determine what needs to be done.
这个答案有帮助吗?
I think you';re asking for trouble trying to fix this. Spend the $50 and get a replacement. Your life could depend on it. Do a Google search for "tire rim & 1998-2002 Honda Accord",
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 129
