跳转到主内容
Released in 2013, the Alienware X51 R2 is an updated version of the original Alienware X51 desktop gaming computer. It has a compact case, but can be upgraded with many off-the-shelf PC components.
2 个问题 查看全部
Getting stuck in a reset loop. reset, boot, reset, boot, reset,boot
I am getting random BSOD showing up on my X51 R2. It all started after a windows 10 update (I already had 10). The computer sometimes games for an hour and other times only 2 minutes before showing a BSOD and getting stuck in a boot/ reset cycle. It resets, boots for 1-2 seconds with the fan on full speed, then resets. This cycle carries on indefinately until I turn off the mains power.
I found a windows STOP CODE on a BSOD... 'BAD_POOL_HEADER'
I have seen 6 different windows stop codes
Looking into the 'fault memory' of the computer it is not logging these crashes as faults as there is no sign of a crash or reason
Please help#!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
I've looked up the model X51 R2, there are various configurations, if you could tell me more about yours I could help more, what mobo, how much ram etc
However in the mean time you could try the following if you could confidently open and remove the ram sticks.
  1. Turn off and remove power cable.
  2. Open case and identify where your ram is.
  3. On the motherboard beside the ram slots there should be (although not always) numbers that indicate what order the rams slots are in, if not, remember what order they are in (or take pictures). Usually the slot furtherest away from the cpu is the first slot. Or refer to your mobos manual if you still have it.
  4. Remove the all the ram.
  5. Take one stick a put it in the first slot, sometimes called slot 1, sometimes 0.
  6. Try to boot.
  7. If you still get the error you may have found the dud stick.
  8. Power off the pc remove power cable.
  9. Remove the stick.
  10. Put in the other stick.
  11. Power on.
One of many things can happen now;
It works, in which case you have the bad stick in your hand
It doesn't work, both sticks somehow died at the same time (extremely unlikely), OR your ram slot is damaged.
Let me know how you get on.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Dan 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 8
总计 1,743
