MacBook A1278 2008 backlight issue
I having backlight issues. I have researched all over the internet with no luck on finding the location of the backlight fuse.
Everything else works great on the computer besides barely being able to see the screen. I have all the necessary tools as well as a donor board to take parts from.
I'm just unable to locate the fuse! If anyone has any further information on this motherboard it would be greatly appreciated.
Getting Frustrated! Been without my poor MacBook for 3 months!
I've replaced the LCD and LCD cable (3 times!) Can anyone help?
2条评论
Can you tell us if an external monitor worked and did you aim a flashlight though the Apple logo (poor mans backlight) to see if you could even see your desktop icons.
If you can see an image on both then you'll need to focus on the backlight logic.
由 Dan 完成的
Works perfect on external monitor and you can slightly see the display coming from the screen, however it is still present. I do notice there to be some indications of corrosion where the lcd cable connects(which you can see I the last image I posted). Could a bad lcd connector cause no backlight? Is it possible for the fuse to still be bad although it has continuity?Thank you!
由 Niko 完成的
