跳转到主内容
The LG K7 is smartphone released by LG in February 2016 and runs on Android 5.1.
89 个问题 查看全部
What is this golden piece?
Hello,
i had a question about what this golden contact sticker does for the phone. i received a screen replacement (purchased from ebay) that has the plastic backing on the screen, but it is missing this piece in the red square. i can only assume it's important, can you please tell me what it is for? thank you.
http://i1383.photobucket.com/albums/ah29...
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Hi Lauren! The reason you do not have that piece in the replacement part is because you are meant to use the one you currently have. I could not tell you for sure what the part does just from the picture, however it is important and appears to be connected to your main board. I don't believe it is a sticker but in fact a piece of hardware.
A lot of handheld devices use near paper thin circuits that literally "stick" on the phone backing or other surfaces. There appears to be writing on the piece, if you could post that or give us a clear picture of it, we may be able to use that to find out exactly what it is and does :)
If we take a look at the link below we can see the same piece very clear. Take a look:
The part in the picture above is a digitizer frame, and it does in fact come with the piece you mention. So I can only assume that the piece in your photo deals with your display and digitizer. It may even be the connection between your digitizer analyzing touch and that piece passing the info onto your motherboard.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Lauren EGle 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 43
