跳转到主内容
这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
4994 个问题 查看全部
Replaced screen, worked for 3 days then died suddenly.
Replaced the screen. Worked great for 3 days than suddenly died and will not turn back on. iTunes on a CPU recognizes that it is plugged in. Did the screws right, battery disconnected when taking screen off. Went back and absolutely made sure the screws were right. Triple checked all connections. No damage and connected good. Did I just get a faulty screen or is it the dreaded backlight problem I keep seeing. It does NOT vibrate when I plug it into the CPU or when I flick the vibrate sound button which makes me think power issue?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
You can check if the backlight has blown by shining a torch light on the screen, if there is no backlight then you'll be able to faintly see the screen when the light is shone on it. If the backlight is fine then its probably just a faulty screen, you'll need another screen to test and confirm.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
trimeye 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 44
