跳转到主内容
Released June 2014, identified by model number 15-d076nr
7 个问题 查看全部
My laptop won't turn on
I have drained the battery and done all the steps provided by most basic Google help has suggested, but my laptop still will not turn on. Heeeelp!!!! I don't care if I have to reformat my laptop after, I just want my laptop to turn on
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 8
9条评论
Have you left it on the charger for atleast 24 hours?
完成的
Yes I've made sure 1st to drain the battery to reset any static energy, but now I have my laptop totally charged, still nothing
完成的
I had a ѕіmіlаr іѕѕuе, wоkе up lаѕt week аnd mу lарtор rеfuѕеd tо ѕwіtсh оn
Trіеd еvеrуthіng but nothing wоrkеd.
Finally I managed tо fіx thе рrоblеm. I gоt hеlр from Wіndоwѕ ѕuрроrt
Fоllоw the ѕtерѕ here: http://bit.ly/BlackscreenOD
It should ѕоlvе thе іѕѕuе
完成的
Thnx alot Kevin!!!
完成的
Am having similar issue with hp15 laptop
完成的
显示更多的4条评论
添加一条评论
5个答案
已选择的解决方案
Dont know what you've tried but lets start with the basics and work out from there . Lets do a static discharge first . Remove the battery and unplug the power adapter once thats done hold down the power button for 60 seconds . now reinstall the battery , plug in your power adapter and try to power on. If you find no joy we can move on the the ram . remove the ram cover plate or the back depending on your model . then remove the ram and reseat it . then try to boot the laptop . if no go then remove one stick of ram and then try to reboot if that doesnt work switch the ram around so you have the other stick in and try to boot . If you still have no joy try the ram in different dimm slots . If you still have no boot then remove the back cover and check the power at the power port with a multi meter. look for broken solder joints at the plug inspect the plug to see if it may be the problem . It may be a good idea to check the power adapter to see if its actually charging the battery. This will give you a good place to start looking once done this contact use and we can take you further into the laptop. could you also supply use with more info like does the fan spin up? do you hear the hard drive spin up? are any of the LEDs on the laptop lighting up? or is it completely dead ? Try these then if you have no joy answer these and we can get back with more help
这个答案有帮助吗?
得分 4
9条评论:
All the lights are still lit up their is no sounds coming from the fan or any other device
完成的
Theirs a red blinking light above the F12 button
完成的
John Doe @johndoe667 have you done everything listed above? for the static discharge the battery needs to be out not just drained
完成的
I've tried all the steps suggested by Jimfixer and still nothing
完成的
What about a cmos reset?
完成的
显示更多的4条评论
添加一条评论
SIMPLE.
I had a similar problem where my HP 5000 wouldnt switch on and the power lamp was on indicating the power cable/charger is okay.
What i did is that i unplugged the AC power cable from the laptop, i pressed the power button and held on to it then i plugged the power cable to the laptop while still holding down the power button and then i released it and voila! It switched on. The problem is now solved!
Good luck
这个答案有帮助吗?
得分 3
11条评论:
Kevin ... thanks that work on my dv6 as well
完成的
Sorry, Kevin... Didn't work for me...
完成的
Kevin thanks, that worked for me as well!
完成的
Kevin thank you my laptop managed to switch on with the way you did your own....you an angel,was getting stressed...❤️❤️❤️❤️❤️
完成的
Kevin thanks my laptop worked in that way❤️❤️❤️❤️❤️❤️❤️
完成的
显示更多的6条评论
添加一条评论
Hello John Doe……I am just finding this thread now….this date….Oct 23 2018
Were You ever able to fix your HP laptop problem?
Mine was doing exactly what yours was doing.
Mine showed the charging LED from orange to white at rear left and that it saw the Hard Drive present LED on the rear right upon power button pressing.
I got mine to work………. I powered all down ( AC and battery)
I open the back cover and pulled the screen connector off near the fan and connected an external monitor out of the HDMI port. It fully powered up when connected this way and works fine but when you reconnect the laptop screen it loads down the supply and will not power up at all…..black and dead !!!
Again i disconnect the laptop screen and reconnect the HDMI monitor and it works fine.
I will be purchasing a new screen for this excellent HP red bullet !! (aka 15-af039ca)
Billy
这个答案有帮助吗?
得分 1
1条评论:
After replacing the screen ($75) it powers up fine now and has been working fine since my repair post in 2018. The screen was loading down the power supply in the laptop and not allowing the laptop to power up properly. $75 LCD screen fixed it !
完成的
添加一条评论
Hi John Doe
Have you browsed the official HP troubleshooting page for your model? There is a link to it on the IFixit device page for your model. It may provide some answers. For example, this support page seems to describe the issue you are having, particularly in regards to the amber F12 light. Try following the steps at the posted link. Following these steps should recover your BIOS, and allow you to install the fix from HP (provided in the link).
https://support.hp.com/us-en/product/hp-...
I hope this resolves the issue. The community will continue to search for a solution until your problem is resolved.
这个答案有帮助吗?
得分 0
1条评论:
Unfortunately it doesn't help, the article provided lists similar issues, but the only real difference is that my laptop won't turn on at all. Everything seems to be running fine as far as the lights and it does charge. However my laptop won't turn on to do any recovery options. Basically I'm looking for help just to get my laptop started.
完成的
添加一条评论
I suggest you test it with a different HDD and RAM , you can borrow a friend's HDD n RAM. If it didn't come up, then the fault could be from the Motherboard.
Do this if you had already done all the suggestions above.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
John Doe 将永远感激不已
浏览统计数据:
过去 24 小时: 6
过去 7 天: 34
过去 30 天: 127
总计 99,585
