Hello John Doe……I am just finding this thread now….this date….Oct 23 2018
Were You ever able to fix your HP laptop problem?
Mine was doing exactly what yours was doing.
Mine showed the charging LED from orange to white at rear left and that it saw the Hard Drive present LED on the rear right upon power button pressing.
I got mine to work………. I powered all down ( AC and battery)
I open the back cover and pulled the screen connector off near the fan and connected an external monitor out of the HDMI port. It fully powered up when connected this way and works fine but when you reconnect the laptop screen it loads down the supply and will not power up at all…..black and dead !!!
Again i disconnect the laptop screen and reconnect the HDMI monitor and it works fine.
I will be purchasing a new screen for this excellent HP red bullet !! (aka 15-af039ca)
Billy
9条评论
Have you left it on the charger for atleast 24 hours?
由 Cameron 完成的
Yes I've made sure 1st to drain the battery to reset any static energy, but now I have my laptop totally charged, still nothing
由 John Doe 完成的
I had a ѕіmіlаr іѕѕuе, wоkе up lаѕt week аnd mу lарtор rеfuѕеd tо ѕwіtсh оn
Trіеd еvеrуthіng but nothing wоrkеd.
Finally I managed tо fіx thе рrоblеm. I gоt hеlр from Wіndоwѕ ѕuрроrt
Fоllоw the ѕtерѕ here: http://bit.ly/BlackscreenOD
It should ѕоlvе thе іѕѕuе
由 Theresa 完成的
Thnx alot Kevin!!!
由 Sathyan K 完成的
Am having similar issue with hp15 laptop
由 Nwachukwu Lawrence 完成的
显示更多的4条评论
