跳转到主内容
苹果 iPhone 5s 于2013年9月10日公布。该设备的维修与以前的型号相似,需要螺丝刀和撬棒。可使用GSM或CDMA / 16、32或64 GB。颜色有银色、金色和太空灰。
3530 个问题 查看全部
White vertical line at boot logo, not booting
Hi all,
Please read the comments I posted for more issues :S, most of below stated issues are fixed.
I've been using my phone for almost a year, without any issues.
Until... I dropped my phone. My screen was completely shattered.
I then repaired the phone, myself, correctly. Making sure every screw was in the right place.
After I repaired the phone, I used it for almost a month and then I started to face some weird issues. First, my whole screen was showing very thin, vertical, pixel lines. Afterwards, I started to face issues with, mostly, black images displayed on the phone.
Black images showed white lines, while images containing red, blue, and all the other colors were displayed normally. Then the phone didn't turn on anymore! All it did when I tried to turn it on, was showing a wide white line at the boot logo, sometimes fading into purple.
I directly tried fixing it myself by opening the phone, removing the metal bracket and detaching and again attaching the screen. I tried booting it multiple times, and suddenly it turned on again!
But this issue wasn't gone forever, as it does the same thing since 2 days ago and it won't turn on anymore. Already tried hard rebooting etc, nothing works.
Does anyone know what the problem is with this phone and how I might be able to fix it?
{Please take a look at the pictures attached to this post.}
Thanks in advance and every bit of info helps!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
its going to need a new screen for sure this is caused by bad/Damaged Ribbon Cables
这个答案有帮助吗?
得分 4
10条评论:
Alright, I'll try this. But is there any way I can test whether the screen is faulty or the motherboard? I don't want to pay for a new screen whilst my motherboard is damaged.. :p
完成的
it is screen 100%
完成的
I agree with this. This is a classic symptom of a damaged LCD ribbon cable (It's the quality of the ribbon cables at fault).
完成的
Alright, so I tried replacing the screen. Screen works perfectly now, no signs of lines etc. However, after the replacement, the screen turned sometimes red/orange and sometimes blue, but didn't boot and entered an infinite bootloop. video: (Reliable video host) https://vimeo.com/213562385
After that, I tried removing the proximity sensor flex cable. Result: Orange and blue screen issues disappeared, same goes for the infinite bootloop. But now I have this problem...: The phone doesn't boot.. it just shows the apple logo and directly turns off: https://vimeo.com/213563946
ITunes didn't recognize my iPhone either, so I tried putting it in DFU mode, and suddenly it did recognize it.
Does anyone have a clue of what I could try?
I WILL LITERALLY BE ETERNALLY GRATEFUL!! :D
完成的
Do a update via 3UTools with flash + retain user data while flashing.
OR
iTunes recovery mode update (Do not use DFU) and pray that it updates to the latest OS 10.3.x as of now and boot.
If that doesn't work which usually errors to some error -2x then a restore is required.
Sounds like front camera assembly will need replacing. Maybe consider trying the old screen without that plugged in to see if it still does that white vertical line thing with the apple logo?
完成的
显示更多的5条评论
添加一条评论
Hdd problem. Power on reset its working after high temperatur in hdd
这个答案有帮助吗?
得分 0
2条评论:
@khairi hi, first I would like to thank you for your reply!
However, I don't quite get what you mean with "Power on reset its working after high temperature in hdd"
Could you clear this up for me and is this repairable?
With kind regards, Nabil
完成的
anyone left with hints? :S
Or is there any way I can try to recover my images and stuff from the phone through dfu/recovery mode before I try torestore it? It was jailbroken if that helps
完成的
添加一条评论
添加你的答案
nabil 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 11
总计 1,228
