跳转到主内容
电脑制造商联想所生产的台式机的维修和支持指南。
97 个问题 查看全部
Will not turn on
Will not turn on when button is pushed
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 21
12条评论
Thinkcentre all-in-one will not come on
完成的
My serial number is
1S3548C8UMJ40G5H
Does not power on.
Answers?
完成的
Hi @Mike Smith
What is the model number of the desktop?
Did you try the suggestions in the Chosen Solution below, you didn't say?
完成的
@jayeff yea I did
Called lenovo tech support and apparently the pc downloaded an update that has caused this issue.
完成的
显示更多的7条评论
添加一条评论
3个答案
已选择的解决方案
Hi,
Try disconnecting everything from the motherboard except the PSU, the RAM and the video card (if not using onboard video), i.e. HDD, ODD, any other cards etc. and see if it starts and if you can get into BIOS.
If the PC still doesn't start, try the paper clip test to see if the PSU starts OK. Here is a link that shows how to do it. If the PSU doesn't start using the test method it is faulty and needs to be replaced.
If the PSU does start OK, then use a DMM's (Digital Multimeter) Voltmeter function to measure the output voltages from the PSU. Also check with the DMM's Ohmmeter function the the desktop's Power button has continuity when operated.
If all the tests prove OK then there is a problem with the motherboard.
这个答案有帮助吗?
得分 5
14条评论:
model 71G thinkThink center CPU
完成的
model 71G Thinkcenter IBM cpu not switching on
完成的
Thinkpad R40
完成的
Hi @ Sienna Tomkins,
The answer above was for a desktop PC and not a laptop.
Here's a link to the service manual for your model laptop.
Scroll to p.39 to view the options to check out the power system.
Do you get any indications at all on the laptop when the charger is connected and switched on or when you go to start the laptop, power light or any other light etc?
完成的
Try removing the memory strips and re inserting, this fixed my issue
完成的
显示更多的9条评论
添加一条评论
最有帮助的答案
Try this first . Unplug the computer then hold the power button down for 60 seconds then release and wait another 30 seconds then hold the power button again for 60 seconds .Now plug in the computer and try to start it . If you have no joy then you need to replace your power supply .
https://www.youtube.com/watch?v=2h_NYl4D...
Hope this helps
这个答案有帮助吗?
得分 18
15条评论:
Replace the PSU? That's a rather hasty move. It could that the GPIO power button has broken, or many other things.
完成的
good point @pccheese I usually throw a power supply in to test on machines I recieve. I always start with a static discharge though but like you suggest it could be a power button . but to be completely honest with you in the 20 some years Ive worked on computers Ive never seen one go bad , not to say it doesnt happen
完成的
by the way @pccheese I am very inpressed with how you stuck with the computer build for Sud Tiwari if I could have given more than one vote I would have
完成的
Thanks jimfixer!
I didn't mean just the power button, I ment that the power cable may be bad or the motherboard power pins may be loose or something etc.
完成的
Hi, I've been having potentially a same same issue. Power supply. After two years of avoiding it, I've finally taken it apart and basically what happened, was a small metal plate ( hinge of the screen section) had unscrewed/-bolted and was pushing against the power connector, and casing, causing this.
After many other checks on everything, here's what I eventually found:
My laptop was working fine, all components fine, and the plug adaptor worked fine. Couldn't get my head round it...
Then, epiphany! The bit you plug into? Where the power gets distributed around the laptop...
There's electrical tape around the wires! . All five power lines from the connector thing to the rest of the laptop (2 red, 2 black, and 1 white) were pulled out, just a tiny bit, but it was within what looks like electrical tape. - so I didn't see this until I'd exhausted every other option and removed the tape from the little metal connector.
Reconnect them, and if everything else works... Hey presto!
完成的
显示更多的10条评论
添加一条评论
Mine belonged to my father in law. It’s a Lenovo Think Centre M58 dead in the water. I went through all the diagnostic advice and determined the power supply was out. I hooked another power supply and unit booted up. I tore the PS down and found several swollen electrolytic capacitors on the PS board. After replacing them the system booted right up.
这个答案有帮助吗?
得分 2
3条评论:
This should have been much more than a score of zero
完成的
@mikeync
Ifixit has no control how people vote or don't vote on answers unless it is a voting ring where people deliberately upvote each other's answers to increase their reputation points, which diminishes the value of the vote score.
Maybe no one as yet has had the same problem as you have found and if they have then maybe they didn't know how to upvote or didn't bother. Who knows.
A lot of the time people who ask questions on this forum don't even bother to respond to the answers provided, indicating whether or not it solved their problem, which can be frustrating sometimes.
C'est la vie
Moderator
完成的
Thanks for the explanation jayeff
完成的
添加一条评论
添加你的答案
George Joyner 将永远感激不已
浏览统计数据:
过去 24 小时: 48
过去 7 天: 332
过去 30 天: 1,362
总计 215,406
