No cold water going into machine
Have a top loader washing machine
Brand ; Simpson Eziset 6kg Simple Wash.
The hot water works only while washing No cold water does
已回答! View the answer 我也有这个问题
这是一个好问题吗?
按维修分数 0
评论:
The machine was working fine .
Until ,having to move house.
May have knocked something out of whack.
I have not solved the problem.Although I have managed to cool the water down .By swoping the two electrical valve connections From the hot water to the cold water nozzel.
Thanks jayeff
Would say it is the inlet valve .I'll add it to the list
添加一条评论
所有超过US$100或包含 Pro Tech工具包的订单免费送货!
浏览我们的商店
3个回答
已选择的解决方案
Hi,
Check that the cold water tap for the washer is turned on and also that water is available from the tap.
Check that the filter in the end of the cold water inlet hose connection into the washing machine is not blocked.
If all of the above are OK then perhaps the machine's cold water inlet valve is either faulty or not being operated by the control board.
If you have a DMM (Digital MultiMeter) you can use its' Ohmmeter function to test that the valve's operating coil is OK. Do this with the power removed from the washer.
Here is a link to a video that in principle shows what to do. (This is not your valve being shown tested).
Hopefully this is of some help.
这个答案有帮助吗?
按维修分数 5
添加一条评论
Check water filter on hose is not blocked. Check cold water tap is working. If they are okay, maybe the inlet solenoid.
这个答案有帮助吗?
按维修分数 0
评论:
Hi @glot ,
How is this any different from the answer above?
@jayeff
Your answer was so good he just couldn't control himself. Maybe short term memory loss.
添加一条评论
A multimeter will check for electrical resistance, however inlet valves do have a mechanical component, that sometimes will simply seize, open, closed or in between.
In your case, its likely it's seized closed. It will need to be replaced. Its pretty simple, and the parts is about AUD$20.
这个答案有帮助吗?
按维修分数 0
添加一条评论
添加你的答案
Oliver 将永远感激不已
浏览统计数据:
过去的24小时: 13
过去的7天: 125
过去的30天: 531
总计 10,940
