跳转到主内容
苹果 iPhone 5c 于2013年9月10日发布。该设备的维修与以前的型号相似,需要螺丝刀和撬机工具。提供GSM或CDMA / 8,16,32 GB /白色,粉红色,黄色,蓝色和绿色。
Bottom microphone and home button won't work again
My iPhone 5c got a violent shock that broke the screen.
I replaced the screen which brought it back to life but the home button wasn't working anymore.
Meanwhile the lighting connector stopped working after cleaning the connector with a metal piece...
So I replaced the lighting connector assembly and I could recharge it again.
Home button still not working.
Noticed that the bottom microphone wasn't working to, had to put the calls on speaker in order to be hearable (makes the phone use the second microphone I guess).
Speakers work well.
So I decided to try a home button ribbon cable replacement but the home button did still not respond.
Tried the home button spring contact cable trick with a screwdriver which didn't react so I realized the spring contact wasn't working and replaced the lighting connector again which includes the microphone.
After replacing it for the second time both the microphone and the home button or home button spring contact do still not work !
So where would the problem be ?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
I mean, it's a bit peculiar, I honestly gotta wonder where you're getting your parts from. Cause if it's not the Lightning dock. Then it would be major chip damage issues on the logic board, and I've honestly never seen anything like that happening
这个答案有帮助吗?
得分 4
3条评论:
Yeah I've had a bad batch of 5C charging port assemblies before. I've noticed that I've had to increase the pressure on the home button contacts sometimes on screen or charging port side to ensure it contacts properly.
Most of the time it's just a bad charging port.
Also OP: For future reference the 5 charging port pins are at the bottom of the charging port so try cleaning only above it and not touching it, these pins only push down and if you put pressure from the left and right sides of the pins it will misalign them causing charging issues.
Also if they get pushed down too hard the contact will go bad, and if it still works it may require you to pull the lightning cable up to get it to charge.
完成的
Lightning connector is working well, on the 2 assemblies I replaced. Everything works except for that microphone and the home button. Chip damage is not to exclude considering the shock the phone underwent, the screen was completely exploded and found 1m from the rest of the phone.
完成的
That's great. I'm recommending, you can anything you want, that you check with a known good part first, then move into the more difficult probabilities
完成的
添加一条评论
添加你的答案
Tay 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 117
