跳转到主内容
苹果官方于2015年9月25日正式发售iPhone6S A1688/A1633机型。 此机型的修理方式与先前几代差不多, 需要螺丝起子及撬棍工具。 同时也适用GSM or CDMA/16, 64 or 123 GB/ 银色, 金色, 深空灰色, 玫瑰金色等机型。
2686 个问题 查看全部
fingerprint id fails after screen change
Hi
Greetings from Tweed Heads Australia .
I have a IP6s 16gb that i bought with a broken screen . I tested the fingerprint (home button) function before i removed the screen and it worked properly. Next i replaced the screen being very careful not to damage the home button cable . With the new screen fitted , the fingerprint id does not work but the home button and everything else on the phone works properly.
The phone seemed to know something was wrong because when i was going through the setup process , a message appeared something like" id failed" .
Only thought i had as to the problem may be i need to swap over the home button extension cable as well.However i don't think this is possible,as the cable seems to be well and truly sandwiched into the display.
Anyhow , do you know where the problem may be?
Do you think it is safe to update to the latest ios 10.3 , as i am concerned it may "brick" the phone.
The bricking is my biggest concern . If the id does not work ,i am ok with that. I don't use it anyway.
Warm regards
Richard
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
4个答案
已选择的解决方案
The home button cable is not good. In this instance you need to exchange the display. You can't just pull the force touch piece off and replace the home button cable. That or you've damaged the home button itself. I dunno though. I be pickin those things off like nose hairs. I stopped using heat years ago
这个答案有帮助吗?
得分 4
1条评论:
Thanks, i think it most likely is a fault in the home cable of the new LCD screen i fitted.Thanks...appreciate your answer
完成的
添加一条评论
It shouldnt brick your device. Biometrics Fails if a error is made this is why i always pull the battery on the phone and use heat to remove the touch id component fom the board to cause minimal chance of damage usually a touch id fail is due to technician error.
Bottom line is it shouldnt brick your phone
这个答案有帮助吗?
得分 0
添加一条评论
Hi there!
First of all, update to iOS10.3.1 will not brick ur device at all, since Apple trying to be nice to 3rd place replacement.
So do u mean u can't use Touch ID at all?
Is it after u reboot ur phone and it pops up "Touch ID can't be activated"?
Or u stock at first setup screen?
I did my screen repair recently and didn't have any issue so far, I even tried to updated to iOS10.3.2 beta, everything works perfectly.
这个答案有帮助吗?
得分 0
添加一条评论
You need to replace extension flex home button cable and your finger print id will work.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
whittymore 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 170
