跳转到主内容
HP’s 6th generation, 2 in 1 laptop, released in July 2016, features a 13.3", 360 degree rotating, Touch Screen, 4GB Memory, and 500GB Hard Drive.
2 个问题 查看全部
Screen glass cracked but touch still working.
I mistakenly used my hands to press down on the hp logo on the top of my laptop and when I opened it there was a tiny crack in the middle of the laptop. Every other thing, such as the touchscreen works fine. The display is also perfect but I really want to fix the cracked glass. Do I need to replace just the glass ?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
3个答案
已选择的解决方案
@suby download the service manual for your computer from here Page 60 will show you how to replace the display panel
这个答案有帮助吗?
得分 3
添加一条评论
最有帮助的答案
If you can find glass then you should be able to replace it but Im only seeing complete displays .If you can find the glass this video will help with the replacement . Not an exact model match but very similar.
https://www.youtube.com/watch?v=MMnHcbgl...
Hope this helps
这个答案有帮助吗?
得分 4
添加一条评论
I have the same problem. What I have found is that you can replace just the glass. Catch is, HP only sells it as part of the entire display assembly. Thus, I have not been able to ID the glass part number with 100% certainty. Third parties sell the glass for around $75 but there are many different part numbers for what seems like the same size screen and series Pavilion.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Subomi Salami 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 5
总计 3,339
