跳转到主内容
Announced September 9th, 2014, this device is Apple's first foray into smart wearables. iFixit's repair manuals are applicable to Apple Watch (steel) and Apple Watch Sport (aluminum).
194 个问题 查看全部
Batteries interchangeable between series?
Are Apple watch batteries interchangeable between all the different series? Say I need to replace a 38mm apple watch battery (original), can I use a 38mm battery for series 1 in the original?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
评论:
Can I use the Apple Watch battery from a series 1 for a series 2
完成的
Hi,
Is the apple watch series 1 and series 2 batteries interchangeable ?
完成的
添加一条评论
2个回答
已选择的解决方案
Sorry no, The original Apple watch uses a different connector system for most everything and that includes the battery. See for your self here:
Original Battery
Series 1 & 2 Battery
这个答案有帮助吗?
得分 4
添加一条评论
**Editing to say that I am 100% sure you can swap batteries between the First Gen and Series 1 Apple watches because I’ve successfully done it countless times.**
I'm pretty confident that you can use a battery from a Series 1 Watch in an Original Apple Watch. The internals between the Original and the newer Series 1 are almost identical. (The processor was about the only change.) In fact, if you order a replacement battery from ifixit.com, the batteries are listed as being compatible with either Watch. Also, the details about the used OEM batteries listing even says that they are taken from either an Original or a Series 1 Watch.
Apple Watch (38 mm, Original & Series 1) Battery
[关联产品丢失或禁用: IF308-010-1]
Series 2 is different though and cannot be used in the earlier models.
Apple Watch (38 mm, Original & Series 1) Battery图片
产品
$16.99
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Sheila Smith 将永远感激不已
浏览统计数据:
过去的24小时: 3
过去的7天: 10
过去的30天: 38
总计 604
