跳转到主内容
这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
4982 个问题 查看全部
iPhone 6 Black Screen but it's on & can still receive calls
This is the first time I have experienced with my Iphone 6. After I charged it, when I was answering e-mails the screen turned black. I was thinking maybe it was the battery. But when I try to charge it again the screen is still black and I got surprised that my Iphone is ringing and I can still answer calls and it alarms and I still receive text messages. But I couldn't open it because the screen display is black. I tried to "hard reset" but It did not work. What could be the problem? I did not drop the iphone. The screen just turned black unexpectedly.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 32
8条评论
Hey guys! I just found out that It might be the backlight that's causing my iphone screen black. Can I possibly fix it by myself?
完成的
The similar thread you can refer to if you want to reset the LCD connector by yourself.
iPhone 4 is working but screen is black?
完成的
I just wanted to thank you for this advice! It worked very well! I was listening to a message from my dentist and the screen went black! I have had the I phone 6 for only a year and a half and this is the first time this has happened! Many thanks for your timely intervention as I so needed it! You are a lifesaver!
完成的
I had the same problem too but with my iPhone 8. My phone seemed to freeze on the weather app so I hit the power button that is when the black screen wouldn't go away. I had notification sounds and an alarm going off. And could still use siri. I asked siri to open the app that froze but it was extremely slow and then was able to power off the phone then I was able to use it normally.
完成的
I have exactly the same issue. My phone just blacks out but it is still responsive as I can receive calls and it vibrates.
I have to press and hold the part below the camera lens for some time before forcing a restart.
It work temporarily before I have to repeat the whole cycle again.
Did you find a way to fix your phone and how?
完成的
显示更多的3条评论
添加一条评论
23个答案
最有帮助的答案
It seems problem with display lcd screen.
Try to press on backside just below cemara there is lcd cable connector. it may possible that cable got loosen and that make your screen black.
Alternately open back cover and remove side screw and reconnect your lcd display screen cable to circuit board.
Try this ipad wont turn on black screen. this is usefull when there is no display or black screen but ipad iphone working.
这个答案有帮助吗?
得分 6
7条评论:
It is very rare for the LCD cable connection plug to go loose from the logic board, it's held down really well with a metal plate on top and screws with foam in between.
I'd be surprised if this was a problem with a phone never opened before.
完成的
If by change you droped your iphone on floor or due to jurk lcd connector may loosen.
Your iphone boot and can receive calls that mean all basic hardware are working fine. Now only possible problem is with external hardware that is your lcd screen. if connector is properly connected that may be soldering of pin of your lcd connector is dry.
And if you have replaced your lcd than lcd is not compatible with your iphone.
完成的
My phone has never been opened. Never been wet or soaked in liquid. The phone was dropped several times few months ago. But it was okay until last week the screen just suddenly went black when i was using it. I have just restored it through itunes using Mac after I back up all the files. But Screen is still Black but it's on and I can still ask assistance to Siri. lol :-( And it's out of warranty already. How much do you think will it cost for a new LCD replacement?
完成的
Depending upon where you live and which lcd your are purchasing like original apple lcd or gray market lcd. I am not in any kind of hardware bussiness so i don't know price.
完成的
Worked perfectly for me. My phone was working just fine and then suddenly the screen started flickering and then went black. I was considering buying a new one, when I googled the issue and just like that, its back to normal!!!
Thanks senata!!
完成的
显示更多的2条评论
添加一条评论
Has the screen been replaced before? Is it currently cracked or glass popping out?
Or is it one that has never been replaced before and screen hasn't been physically damaged.
这个答案有帮助吗?
得分 4
2条评论:
The screen has never been replaced and hasn't been physically damaged.
完成的
My is cracked but one day my phone went dead then i tried to charge it for a whole day and it never came back on. My momma told me it was called a LCD. While my phone cant turn on, I ca hear all y notification sound and when people tries to call me my phone will ring but i cant answer it because the phone has a LCD.
完成的
添加一条评论
Put a strong light on the screen.
1. if you can see icons on the screen, the back light is bad and you need to replace a new LCD screen.
2.If you still can't see anything, open your iPhone and reinstall the LCD screen to see whether it works. If it still not work, you need to replace a new LCD screen.
这个答案有帮助吗?
得分 4
3条评论:
Did that and still doesnt show anything. Tried hard resets. Still nothing except the sounds.
完成的
dude i got a problem with issue no 1. i can see the icon and i can move and use it. so i must replace a new lcd?
完成的
thank you soo mutch i was about to bye a new phone :-) i can now see the icons
完成的
添加一条评论
I would say u need to replace your LCD screen because my cables are connected and everything and it a new battery so I really strongly suggest you replaceing it it can be bought at Walmart for $24.99 and it's easy to put in but yeah
这个答案有帮助吗?
得分 1
添加一条评论
I dropped my iPhone and it cracked my glass screen protector but not my iPhone and the screen went black I hold the wake button and the home button works and all like if the screen functions but I can't see anything
这个答案有帮助吗?
得分 1
添加一条评论
这个答案有帮助吗?
得分 0
2条评论:
Okay, not sure what you used for hard reset but anyway try holding home + power button for 10-15 seconds and try turning the phone on again.
If that still does not work then I'm stumped on what caused the problem.
Other thing I could think of is liquid damage inside the phone.
完成的
Thanks Ben, but I don't think cos' it has never been exposed to liquid. :-(
完成的
添加一条评论
it can probably be your lcd connector its probably not connected
这个答案有帮助吗?
得分 0
1条评论:
or not attached i had this same similar problem
完成的
添加一条评论
Thanks, this was a life saver!
I though my battery was dead when I took my phone out of my purse, but then I could hear a text message come in, and when I switched the phone on and off of vibrate mode, I could feel that working. Then I started getting calls and could not answer them except in my car where my phone connects to the blue tooth-craziness!
This worked perfectly and in less than two minutes I was back in business.
这个答案有帮助吗?
得分 0
添加一条评论
My phone wents black and i just got a new lcd 2 months ago off of ebay idk if i should get a new one and i tried everything please send help
这个答案有帮助吗?
得分 0
添加一条评论
Same thing just happened to mine- I have to put my phone in direct sunlight to be able to see anything, and even then it’s hard to see what I’m doing.
这个答案有帮助吗?
得分 0
添加一条评论
Same thing happens with my I phone 6…can u suggest me now what I do…can I replace may screen or there is any way to solve this problem
这个答案有帮助吗?
得分 0
添加一条评论
I’m having same problem with my 7 plus
same thing have to me
这个答案有帮助吗?
得分 0
添加一条评论
Worked for me to use flashlight on another phone and place directly on the black screen. It allowed me to barely see enough to slide the power off and when it restarted, the screen came on normal. iPhone 7!
这个答案有帮助吗?
得分 0
添加一条评论
The bottom of my iPhone 6 Plus doesn’t work after I dropped it, I can see some of the bottom of it but it’s over the bit where I answer the phone so I can’t do that. What can I do to fix this????
这个答案有帮助吗?
得分 0
添加一条评论
Yes!
When my iPad screen went blurry, then turned black, I thought it was dead for sure. Then I received an incoming call… but with a black screen, I couldn’t answer it!
I turned to a Google search & found ifixit.com with this posted answer,
”Reset the phone (no data loss): press both the home and power buttons for up to 1 minute, releasing when the Apple logo appears.”
Thank you LiraAdela! Your answer fixed my problem!!!
这个答案有帮助吗?
得分 0
添加一条评论
I too have had the same issue. I had less than a quarter of a glass of milk and in my sleep in knocked it and it went on my phone. When i woke up there wasn’t much liquid on the screen at all but then when i clicked the home button it showed my display and the flickered to a black screen. I receive notifications still and it vibrates but it will not let me answer calls or use the screen at all. It still charges and everything but the screen just won’t go from black to normal. Is there anything i can do or is it better to lose hope and get a new phone
这个答案有帮助吗?
得分 0
添加一条评论
Dear Friends, remove sim card tray then insert back. it will work
这个答案有帮助吗?
得分 0
添加一条评论
Same problem here guys I actually opened my iPhone 6s for microphone repair but when I powered it up the home button, Touch ID, and touch were working fine but screen remained black. Don’t know the solution, maybe there’s some issue with LCD connector in my case because I opened the phone, I opened it again and cleaned the connectors but screen remained black. Seems like I have to replace the connectors. I need some advice from you guys, if someone can help me.
这个答案有帮助吗?
得分 0
添加一条评论
how can i turn it on but it keeps making random noise and does not want to turn on for some reason what should I do I try everything
这个答案有帮助吗?
得分 0
添加一条评论
I would say if screen is replace and it still the same then it an ic problem which requires troubleshooting the panel to find the light ic
这个答案有帮助吗?
得分 0
添加一条评论
I have an answer if it blacks out!! You press the on button three times continuously it will send a signal to the apple community that you’re in an emergency and it will turn on!? hope I helped!?
这个答案有帮助吗?
得分 0
添加一条评论
Try this this may solve your problem
https://okadtech.com/iphone-6-black-scre...
这个答案有帮助吗?
得分 0
添加一条评论
I dropped my iphone 6 only a few times but no cracks and all of a sudden my screen goes black but my phone still vibrates when i restart it but it won't light up I also notice that my bluetooth headphones can still connect and it vibrates whenever I get my password wrong. Do I need to replace my LCD? please help
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
debrutz 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 22
过去 30 天: 104
总计 173,018
