联想笔记本电脑的维修和支持指南。
938 个问题 查看全部
How can I open my laptop
Can't physically open my lenovo z500 so can't reach any button. Was working fine before last closing. Now seems to stuck somewhere so can't be open. What to do?
已回答! View the answer 我也有这个问题
这是一个好问题吗?
按维修分数 0
评论:
Wne you say it wont open do you mean your cant open the lid?
Are you saying that your lid doesn't open? Is there a latch you have slide to open it?
George, i looked and there is no latch. Not sure how this can occur unless this person is really weak or doesnt know how a laptop works
Kensington lock slot may also prevent screen from opening.
how so george
显示更多的3条评论
添加一条评论
所有超过US$100或包含 Pro Tech工具包的订单免费送货!
浏览我们的商店
3个回答
已选择的解决方案
AI iona, I don't know exactly what the issue is, but try holding down the power button until it does something.
这个答案有帮助吗?
按维修分数 0
评论:
This is a physicsl issue so I can't press any button because can't physically open it. Actually link also is not working: is written service is unavailable. I have no idea what to try. Anyway thank you for your reply!
@ymkocv, are you under warranty? If so, contact Lenovo. If you aren't, could you please better explain your problem?
添加一条评论
最有帮助的答案
@ymkocv not sure if you physically cannot open your laptop or if it is hang up. If it is a physical issue. Download the service manual from here. If it is hang up and does not start or gets "stuck" while loading, it is possible that your laptop does not recognize the OS on the HDD. You may want to check this by trying to boot from a bootable USB stick or optical disk. check to see if you can access your BIOS by one of two ways:
1- Press on FN+F2 once you turn the machine on
2- Or with the machine off, press on the Novo Button on your left side of the machine then you will find a list of options , just press enter on Bios setting
See if the BIOS recognizes your HDD.
Update (04/02/2017)
Sounds like an issue with a binding hinge. Check to make sure that the hinges looks straight and are not cracked. You may need to try to wiggle it. Worst case scenario will be some brute force and be ready to replace whatever breaks. There is really no other way to open it.
这个答案有帮助吗?
按维修分数 4
评论:
Guys i am not so weak. I am working on this laptop almosr 2 years and this is the first time it happened. There is no any button to lock it. It just can't be physically open
I thought the same and tried i wiggle them but i am afraid to brake them out :(
@ymkocv something has got to give. Sorry but there is no magic trick that I know off.
@ymkocv Oldturkey is right,
添加一条评论
@ymkocv , Aliona, Not being smart, but you are trying to open it up from the right end and not the hinged end. I believe the Lenovo logo will be up side down to you when facing the front. If you are trying it from the correct end then perhaps the hinge is seized. With a hair dryer/heat gun heat up the hinge area until hot( do not melt the plastic) direct the heat up from the bottom in hinge area, then give the lid a good tug to open the lid. If still no luck you may have to disassemble the laptop and check the hinge and lightly lube it with penetrate oil(link below service manual for disassembly). Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
https://download.lenovo.com/consumer/mob...
这个答案有帮助吗?
按维修分数 2
评论:
How can I retrieve my system password. Help please
添加一条评论
添加你的答案
Aliona 将永远感激不已
浏览统计数据:
过去的24小时: 3
过去的7天: 19
过去的30天: 115
总计 3,638
