跳转到主内容
修复你的物品
维修的权力
商店
发布于 2009-2012 年,带 13寸显示屏的 MacBook Pro (一体成型机身款)机型。
4849 个问题 查看全部
How can I identify what year an optical drive is from?
I've been working on macs for about 18 months now, and 1 thing that always frustrates me is replacing the optical drives. I often times can't get a replacement drive to work in a MacBook that I know worked in another MacBook.
I'm told there's a way to identify the optical drive to know exactly what year a1278 or a1286 it will work in, but i'm not sure how to do that.
Does anyone know how to identify that to make it easier to know which optical drives I have in stock will work with which model year MBPs??
已回答! View the answer 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个回答
已选择的解决方案
PowerBook Medic is very good about compatibility listings. Do your search there using the model number of the drive.
这个答案有帮助吗?
得分 4
评论:
thanks for that...
when I look up model UJ868A anywhere, i typically get the answer that they're compatible with all a1278 & a1286 model MacBooks & pros. but i've found that some of these drives work in some models but not others.
is there a better way to look this up or know?
完成的
添加一条评论
添加你的答案
dollartripclub 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 46
