跳转到主内容
苹果 iPhone 5s 于2013年9月10日公布。该设备的维修与以前的型号相似,需要螺丝刀和撬棒。可使用GSM或CDMA / 16、32或64 GB。颜色有银色、金色和太空灰。
4098 个问题 查看全部
iPhone 5s - changed screen - both camera and flash does not work
i changed my iphone 5s screen, now both cameras does not work, open the camera app, the screen is black.
also try the flash from control center, i press the flash light, but it would not turn on.
I switch with another iphone 5s screen with the front camera and back camera.
both cameras work in the other iphone 5s.
any other things i can try? or, its a motherboard issue?
thanks.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个回答
已选择的解决方案
When you changed the screen, did the replacement screen come with the camera already installed or did you transfer it from your broken screen? If it came with camera and sensors, then does the old, cracked screen (and it camera and sensors) work?
If the cameras work in another iPhone, then your problem is most likely on the logic board. There is a common LDO (voltage regulator) for the cameras and that could be defective. It could also be the connectors themselves which are damaged.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Charles 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 69
