After a power outage the TV will not come on
I have an Emerson 32" model # LE320EM3
Serial# DS1A122810Z669 that after a power outage will not come on. I checked the 4 amp 125 volt fuse and it was blown. Replaced the fuse and still nothing, no standby red light. I bought the TV from a friend and have no clue of it is a LCD, LED or what type of TV it is, there is no markings that say what it is. Any ideas???
2条评论
Hi @scottecamel ,
The number is helpful if you have a schematic diagram, which I don't.
Hopefully you can still read the capacitor's value that is printed on it.
You need to set the DMM to the Ohm function. Make sure that the TV is totally disconnected from the power outlet when using an Ohmmeter for testing.
btw you original comment has been transferred to its' own question After a power outage the TV will not come on
This way you will be able to add pictures etc if things progress.
Also I noticed when searching your model that they have 'power kits' available online should this be more helpful.
https://www.google.com.au/webhp?sourceid...
由 jayeff 完成的
Mine shows the red stand by light and will go to green when trying to turn on but will make a weird humming noise and go back to red… Did anyone get a fix?
I just bought a new 40” Vizio for under $200, as the Emerson has to be 7-10 years old. But if I could fix it I can use it outside on my patio until it breaks or gets stolen. (LIFE)
由 Chris Gomez 完成的
