跳转到主内容
Repair guides and support for the Nikon D800 and D800E digital SLR cameras announced in February 2012.
18 个问题 查看全部
Not able to change out lens. Either camera or lens will not release.
I am not able to change out lenses. The Nikon lens that is currently on the camera will not release. Or the camera will not release the lens. I'm not sure if it's the lens or the camera that is the problem.
Can anyone give me some advice!
Thank you
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
it seems this is a pretty common problem with this series, you might need to send it in.
http://www.sportsshooter.com/message_dis...
try reseating it like you were going to try and put the lens on and twist it into the lock position and then try and unlock it. it might be stuck but if that doesn't work you might need to send it in :(
Sorry!!
这个答案有帮助吗?
得分 0
添加一条评论
Hi, I had this problem one day with my 50mm 1.4 af-s. It came from a screw in the back of the lens that was unscrewed. I forced ... I had no choice but it is a very big risk. good luck
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
edington 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 274
