跳转到主内容
Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 16 or 32 GB capacity / black or white plastic back.
1961 个问题 查看全部
cannot trun on my iPhone
i had charged my iphone with my computer USB after it indicated charged i unpluged usb and it turned off and since then its not turn on again.
已回答! View the answer 我也有这个问题
这是一个好问题吗?
按维修分数 0
添加一条评论
Macbook 电池维修套装
起价 $69.99
Buy Now
Macbook 电池维修套装
起价 $69.99
Buy Now
1个答案
已选择的解决方案
Try a wall charger and see if it turns on after a while of charging. Might just be that the battery is to run down to charge or to hold a charge over the USB port, or that you might have to change your battery.Good luck
这个答案有帮助吗?
按维修分数 1
添加一条评论
添加你的答案
suresh 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 682
