跳转到主内容
Device and repair guides for the RCA 10 Viking Pro, an Android tablet with detachable keyboard that can be identified by model number RCT6303W87 DK.
426 个问题 查看全部
Can't connect to camera
Tells me app maybe using it. I've closed all apps, still want connect, am I missing one or is there something else?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 4
添加一条评论
2个答案
最有帮助的答案
Hello blueeyedtweety6
How was your day?
Steps to try mate.
  1. First try the easiest. Restart the tablet and see if the camera problem is still there.
  2. If it is try restarting your tablet in safe mode to see if it is a app that is coursing the camera problem. How to restart into safe mode
  3. # If the camera now works then most likely and downloaded app is coursing the problem. Start uninstalling apps once out of safe mode to see if you suddenly can use the camera again.
  4. If the camera still doesn't work in safe mode then I recommend restarting the tablet back into normal mode and backing up all of your data. I would then recommend doing a factory reset.
  5. If a factory reset doesn't work then most likely it is the camera itself needs to be replaced or reconnected.
Hope this helps
David
My Computer Dude
这个答案有帮助吗?
得分 3
1条评论:
This was very helpful, thank you. I didn't know you could restart in safe mode.
完成的
添加一条评论
  1. First try to restart the tablet.
  2. If that doesn't help it could be a app locking the camera. Try rebooting into safe mode (https://blog.chinavasion.com/15120/how-t...)
    1. If in safe mode the camera works then its an app. Restart to get out of safemode and start uninstalling apps until you find the one that is coursing the problem.
    2. If the camera doesn't work in safemode then restart into normal mode backup your data and try a factory reset.
If it still doesn't work it might be the camera itself.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
blueeyedtweety6 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 2,123
