跳转到主内容
The Kenmore 90 Series is a washing machine manufactured by Kenmore.
266 个问题 查看全部
Why is the water trickling out?
The water started slowly filling at first just on the sides, trickling out hot water even if I had the cycle on cold. Takes two forever for the tub to fill. I thought I had out smarted it by hooking my cold water up in the hot water hose. Nope. Just prolonged the inevitable. It is doing it again. What can i do to fix this?!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
@jmalm87,Jess, Remove hoses from washer and house supply, check for good water pressure from taps and check hoses/screens for blockage. If the water inlet valve defective, the washer could fill very slowly or not let water run at all. Check the fill valve screen if OK, replace the fill valve. See the trouble shooting repair links below. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
https://www.familyhandyman.com/appliance...
http://removeandreplace.com/2015/09/29/w...
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Jess 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 5
总计 975
