跳转到主内容
Apple的 MacBook Pro 的產品線是專為可望極致效能專業使用者所打造。MacBook Pro 产品线包括了MacBook Pro 13" (一體成型機身款), MacBook Pro 15", MacBook Pro 15"(一體成型機款), MacBook Pro 17" 和 MacBook Pro 17" (一體成型機款)。
18248 个问题 查看全部
Black screen after computer was dropped in the floor.
My daughter dropped the computer in the floor. I can hear it running but it only has a black screen. What should I try?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
评论:
What model is your laptop?Try hooking it up to another monitor. do you get an image? If thats the case, replace the screen. Ill provide a good answer later on how to do this.
完成的
It is a MacBook Pro A 1286
完成的
@maryetatar Do you know the year?
完成的
添加一条评论
1个答案
最有帮助的答案
That could be a cable just needing reseated. It could also be what cameron said and it could be needing a whole screen. If you can not open the computer up to check the cable then follow cameron steps. It could be that simple though just reseat the Display cable. Hope this helps.
这个答案有帮助吗?
得分 2
评论:
How do I know if I can open it up? I am not a computer genius by any means...
完成的
@iceplow Ill handle this, this is more my tempo, if you dont mind.
完成的
Cameron telling someone that they need to get a new display when it could be a simple reseating of the cable is not the way to go about it. If you do work on these things for a living as I do then wouldn't that be part of your troubleshooting steps? I'm not trying to make you look bad thats not my intentions at all. The purpose for this sight was to give people good advice thats what I'm trying to do when I tell Maryetatar to try that first.
完成的
As for answering you Maryetater you would look on the bottom of the computer it should have a type of screw holding the Bottom of the computer to the rest of the computer if those are cross tipped screws then it would be easy for you to take apart and check that cable. When doing it you would need to flip the lever then pull straight out and then do that in reverse make sure the lever is fully down after plugging it back in.
完成的
@iceplow Sorry. I agree with you there, when i made my answer that would be my first step. Im just trying to get all the details as @mayer constantly is telling me to so i can help get all the right info.
完成的
添加一条评论
添加你的答案
Maryetatar082683 将永远感激不已
浏览统计数据:
过去的24小时: 8
过去的7天: 38
过去的30天: 165
总计 10,745
