What is the minimum and original thickness for motorcycle brake rotor?
I'll like to know when should I change my brake rotor.
What's the minimum front and rear brake rotor thickness and what's the original thickness for Yamaha xt600e 2002.
derayon, I beleive this to be the dimensions of your stock rotor. You can compare the dimensions to the rotor that is on the bike. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
Dimensions (mm)
Outside Diameter 282,0
Inside Diameter 132,0
Bolt Hole Circumference 150,0
Bolt Hole Quantity 6
Bolt Hole Size 8,5
Thickness 5mm new
Minimal Thickness 4.5mm
Offset 0
Bolt Hole Type Straight
这个答案有帮助吗?
derayon,did the info. help.
Yes it did help thanks
I checked it today and it seems to be the same
过去 24 小时: 4
过去 7 天: 21
过去 30 天: 66
总计 6,327
1条评论
Ok thank you. I got one more question.
My xt600e originally had a 21 front and before I had it the person changed it to a 17 front.
It may be a idiot question but my stock rotor for xt600e would it fit the now 17 rim?
Or do I have to find/get a rotor specific for 17 rim?
由 derayon 完成的
