跳转到主内容
2014年9月19日发布的iphone 6 Plus有着比iphone 6大的5.5英寸屏幕。
1525 个问题 查看全部
Problem after changing charging IC
Hello everybody,
The iphone 6 plus battery started to drain, I tried everything from changing the battery and chargers to changing the U1700 ic chip which actually worked!
But unfortunately I couldn't connect it to a computer nor plug it in a charger, it works temporarily then turns off with apple logo loopinf when plugged in, i tried changing the ic chip twice and the problem hasn't been solved, anyone has any solution for this frustrating problem?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
Its possible You damaged additional components when replacing the charging ic have you tested the Components next to the charging ic for damage?
这个答案有帮助吗?
得分 0
添加一条评论
i have iphone 6 plus charging not working i change u2 ic but not working
please help me
这个答案有帮助吗?
得分 0
1条评论:
i have iphone 6plus not charging i change u2 ic but still problem plss help me
完成的
添加一条评论
添加你的答案
Yousef 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 12
总计 2,574
