跳转到主内容
这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
4994 个问题 查看全部
Why wont my phone turn on?
My I phone 6 has been putt away since i brought a 7 and i want to get it back out,
i have tried charging it for ridiculous hours and plugging it into my computer but i still cant get it to turn on.
When i plug it in the screen brings up the low battery logo, it then brings up the apple logo and turns off again.
If you have the lights off you can see the phone tries to turn on a glows a navy type colour.
I took it to the phone repair man to see if it was the battery and it did the same thing with a new battery in it.
please help
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
2条评论:
I'm sure the repair man had the knowledge but just a thought, was the new battery that you tried a brand new out of the box battery or one that he knew was good? A new out of box should be charged before it gets used or it may not be charged in itself because I'm sure most batteries recommend to charge before the first use.
完成的
Did this iPhone have any damage before you put it away ?
完成的
添加一条评论
1个答案
I would suggest trying to unplug the power button flex from the circuit board and plugging in the charger and see if it will come on then, if that doesn't work try a new battery, charging port, screen and if all else fails plug it into iTunes and put it in DFU mode and do a restore. you will lose all info.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
emmafinemore 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 139
