跳转到主内容
All screwdrivers manufactured by iFixit and sold on iFixit.com
13 个问题 查看全部
Is the IFIXIT screwdriver magnetic?
I need an answer to whether the IFIXIT screwdriver is magnetic or not.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个回答
已选择的解决方案
Yes it is. I own the kit and the bits go in with a satisfying magnetic 'click'. And screws that can be attracted by a magnet stick to it no issues. If your considering getting any ifixit toolkits GET IT it is one of the best purchases ive ever made
这个答案有帮助吗?
得分 5
添加一条评论
This is a mixed answer. In theory both the 1/4 in driver and 4mm driver are magnetized. The magnet work well in the 4mm driver and is strong enough to retain the bits as well as the screws on the end of the bit. However, on the 1/4 driver the magnet is much weaker and is only strong enough to retain the bits but barely passes through with enough residual strength to hold a screw on the tip of the bits. I have two complete sets and the larger 1/4 driver is the same in both. It’s a very annoying shortfall on an otherwise nearly perfect set.
这个答案有帮助吗?
得分 4
评论:
The 1/4 in driver has strong magnets now.. I cant pull the bits out of it without tools. If only it had a magnet switch. I found a workaround! Stuck piece of paper napkin in driver and its better!
完成的
添加一条评论
添加你的答案
Albert Einstein 将永远感激不已
浏览统计数据:
过去的24小时: 3
过去的7天: 36
过去的30天: 131
总计 3,760
