跳转到主内容
这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
5202 个问题 查看全部
Mic is not working properly, even after replacing
My iPhone 6 mic not delivering full voice to other , compare to other iPhones only 50% voice other can hear compare to other iPhone.
I also replace mic , along with full card with which mic is attached.
What to do ., how it get solved
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
评论:
Have you checked the speaker filters and cleaned them?
完成的
Is after changing logic board problem get solved
完成的
添加一条评论
1个回答
已选择的解决方案
I've just had the same problem on the same iPhone model. Took the same steps and replaced the dock but without any result at all. Checked the connector on the board under a microscope and it shows no damage.
Full restore didn't bring any result either.
Unfortunately I came to the conclusion that is a logic board problem, some component went bad and needs deeper diagnostic and high microsoldering repair skills.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Maninderjit Singh 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 56
