跳转到主内容
问题已关闭
why is my power adapter shorting out
Every time I put the power adapter in the computer, the blue light on the power adapter goes out, and it sounds like there is a electrical short. How do I solve this problem. As a result, my computer won't come on and the battery isn't being charged. Please help!!! DOES THE DC-INBOARD NEEDS TO BE REPLACED? IS THIS WHY THE POWER ADAPTER IS SHORTNING OUT?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
已选择的解决方案
Hi! It could be the power adapter itself that is a problem, or it could be the DC-in port that the plug on the power adapter connects to. Since replacing the DC-in on a 12" PowerBook is a difficult procedure, I'd say the first step is to get a hold of a known-good power adapter and determine whether it solves the problem (which means your power adapter is bad), or the problem still exists (which means your DC-in is bad). If it's your DC-in, let me know, and I can point you to the part and the iFixit guide to replacement.
I would also try plugging the AC adapter into a completely different electrical outlet, preferably on the other side of the house. Sometimes if you have bad wiring, or the electrical port is overloaded, etc., if can cause bizarre behavior, although in your case it's probably not that...but it can't hurt to rule it out.
Also, you mention a "blue light", whereas it should actually be green or yellow. Is it really blue? If so, do you have an actual Apple AC adapter or 3rd party? If it's 3rd party, quirks related to that might be all the more reason to try a genuine Apple AC adapter.
On a side note, I'm curious if the computer works on battery power?
这个答案有帮助吗?
得分 3
添加一条评论
Please allow me to thank you "rdklincorporated" your compassion and knowledge is to be commended, and appreciated. yes, it is a 3rd party power adapter. as for the battery, I'm not sure, because the g4 was given to me, but at that time it was workning just fine.
这个答案有帮助吗?
得分 0
添加一条评论
also, ifixit has incredible step by step guides that are extremely helpful.
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 1,251
