苹果 iPhone 5s 于2013年9月10日公布。该设备的维修与以前的型号相似,需要螺丝刀和撬棒。可使用GSM或CDMA / 16、32或64 GB。颜色有银色、金色和太空灰。
3839 个问题 查看全部
Will replacing the iPhone screen fix an iPhone's screen touch?
I water damaged my iPhone 5, and I have been phone less for about a year. Due to finicial problems I can not get a new phone soon. My friend says he has an old phone that doesn't work because the touch screen won't work. I was wondering if I could take his faulty screen and replace it with my iPhone's screen. If I replace his screen with mine, will it fix the touch on his phone?
已回答! View the answer 我也有这个问题
这是一个好问题吗?
按维修分数 1
添加一条评论
所有超过US$100或包含 Pro Tech工具包的订单免费送货!
浏览我们的商店
4个回答
已选择的解决方案
No idea. Only way is to try it out.
这个答案有帮助吗?
按维修分数 1
评论:
The thing is I wanna know if it will work before buying the tools and screen parts.
Open up and take pictures of the inside of the phone especially the screen FPC connectors on the logic board. If we think there are no signs of liquid damage or physical damage inside then it's a good idea to try another replacement screen.
添加一条评论
最有帮助的答案
it should be of the same model, if your iphone's screen connectors was not corroded due to water damage, then it is possible that it will work out.
这个答案有帮助吗?
按维修分数 3
评论:
Thanks you, it's very helpful
you're always welcome :)
添加一条评论
My advise is just try to switch your screen whit the faulty one from your friends phone, you don't have to spend much money on tools and parts. You only need a pentalope screwdriver and a suction cup to test the screen and if it is working then you also need a philips screwdriver.
这个答案有帮助吗?
按维修分数 2
评论:
Thanks for your help!
添加一条评论
I do not like your odds. Its probably the screen connectors itself. :( maybe buy a cheap screen from ebay?
这个答案有帮助吗?
按维修分数 0
评论:
The thing is I wanna know if it will work before I buy the tools and screen parts
If it was dropped?
no I do not think it will work. Best bet is do go with ebay
添加一条评论
添加你的答案
DJ and Joce 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 95
