跳转到主内容
2014年9月19日发布的iphone 6 Plus有着比iphone 6大的5.5英寸屏幕。
1525 个问题 查看全部
Question about screen replacement.
I bent a flex cable on my xracked iphone 6+ screen so I am ordering a new one. I'm lazy and don't want to grab the old lcd shield plate off my current screen and am ordering a pre assembled one. I plan to replace the home button to keep touch id but will I also need to replace the home button flex cable? I was unable to find any information about this thank
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
已选择的解决方案
If you are buying a preassembled screen then you should transfer the home button from the old screen to a new one.
这个答案有帮助吗?
得分 2
2条评论:
Yeah I know but just the home button or the flex cable aswell? If it incldues a home buton flex cable.
完成的
Preassembled screens already have the home button extension cable which is part of the back metal plate for the screen. You plug in the home button which has a cable coming from it into that extension cable. It's self explanatory when you see a preassembled screen.
https://d3nevzfk7ii3be.cloudfront.net/ig...
完成的
添加一条评论
the flex cable should already come with your new preassembled screen
这个答案有帮助吗?
得分 0
添加一条评论
Only replace the original home button to the new screen will do the job.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Dylan 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 75
