跳转到主内容
The Super Nintendo Entertainment System (SNES), or simply the Super Nintendo, is a 16bit gaming console released by Nintendo in 1990. The Super Nintendo was one of the best sellers of its time and still has a large fanbase today.
103 个问题 查看全部
Why does the red light keep flashing how do I fix it
Red light keep flashing how do I get it to stop and work again?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个回答
最有帮助的答案
This can mean a number of things, one of which is a dirty or broken 62 pin connector (where the game connects into the SNES). The red blinking light can come up if its unable to read a cartridge, or the cartridge connector has gone bad. Try sanding the pins of the 62 pin in the SNES with a fine grit sandpaper, then testing the system again with a game. You can also clean the cartridge connector's pins with isoproyrol alcohol 80% or higher and a q-tip. If that doesn't work, then you may need to replace the cartridge connector. Depending on which version of the SNES you have, the 62 pin should be removable by hand, making for an easy replacement.
You can clean it by opening the slot the cartridge enters, although it might be easier to remove the top of the case. If you do need to remove the top of the case, you'll need a gamebit screwdriver which can be found here, or at your local classic gaming shop. The guide for the SNES can be found here. To remove the top of the case, you should only need the first few steps.
Let me know if you have any more questions.
- Ben
Gamebit 4.5mm图片
产品
Gamebit 4.5mm
$24.99
这个答案有帮助吗?
得分 1
评论:
Thank you for replying! I found out my adapter was shot and needed replacing it working like a charm!
完成的
No Problem! Happy to help.
完成的
添加一条评论
添加你的答案
BRITTNEY RONAN 将永远感激不已
浏览统计数据:
过去的24小时: 1
过去的7天: 6
过去的30天: 30
总计 2,647
