Where can I find a replacement screen
Where can I find a replacement screen for a M55C2 VIZIO TV
Hi,
Replacement screens, if you are lucky enough to find one, cost nearly as much as a new TV.
You could try removing the back off the TV and finding the screen part number which is printed on the back of the LCD panel and then searching online using the part number to see if you get results for suppliers.
Do not be surprised that if you do get a result that it doesn't mention Vizio but some other manufacturer's name. LCD panels are made to order by specialist LCD panel manufacturers for the TV manufacturers and they usually do not sell only 1 screen at a time.
If you cannot locate a screen this way one option is to advertise your TV for sale as faulty - good for parts. This way you should be able to recoup some of the cost of buying a new TV.
这个答案有帮助吗?
for what it’s worth, after removing the cracked LCD screen from a TV, I found it makes an excellent shop light, and it’s remotely operable too! :p Also, getting the screen out wasn’t very difficult or risky, and if an LCD becomes available, it will be easy to replace. (Speaking specifically of a Vizio E32-C1)
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 13
过去 30 天: 69
总计 5,342
1条评论
donde puedo encontrar una tienda que venda una pantalla de una televicion vizio m55-c2
由 flores11007 完成的
