跳转到主内容
2.26 or 2.4 GHz / White plastic unibody enclosure
646 个问题 查看全部
put a mini disc in dvd rom drive now cant get out
What do i do? (look at short question)
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
3个答案
已选择的解决方案
If luck is on your side, try booting while holding down the trackpad button (which, in this instance, is the entire trackpad).
If that does not eject the disc, you will probably need to remove the optical drive, pull the cover off the drive, and remove the mini disc.
Unfortunately, that machine is so new that there aren't many repair guides available.
If you are adventurous, give it a try! There are 10 identical #00 screws to remove the bottom case. After removing the bottom case, you will need to remove the white hinge vent (8 screws: 4 #00, 4 T8). Next, remove the speaker by disconnecting the speaker cables and antenna cables and unscrewing 3 #00 screws. Finally, disconnect the optical drive cable and remove 3 #00 screws holding the optical drive in place.
If you aren't into that, wait for a repair manual to show up here. It's in the queue :)
这个答案有帮助吗?
得分 1
添加一条评论
最有帮助的答案
Use the double-sticky tape on an old CD/DVD trick.
Good Luck,
N.
这个答案有帮助吗?
得分 3
1条评论:
Wow, I'll have to remember that! Thanks!
完成的
添加一条评论
Use gravity and inertia. Hold the book tightly with the disk opening pointing down and shake it out using short abrupt downward thrusts.
这个答案有帮助吗?
得分 3
1条评论:
worth a try +
完成的
添加一条评论
添加你的答案
Benjamin Speer 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 1,782
