跳转到主内容
修复你的物品
维修的权力
配件 & 工具
这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
5080 个问题 查看全部
What else is required for iPhone 6 body replacement?
Hello everyone
My iPhone 6 body is very badly damaged and hence I want to replace it. The display also pops up due to damaged body. I've ordered one body from dhgate which sends me the body itself, the volume and power buttons, and the sim tray. Is there anything else needed to replace the body of my iPhone 6?
If yes then can somebody mention the name of the items and if possible, purchase links of those items?
Thanks to all the readers in advance
已回答! View the answer 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
任天堂 Switch 套装
快速恢复到游戏的状态
购买 Switch 套装
任天堂 Switch 套装
快速恢复到游戏的状态
购买 Switch 套装
1个回答
已选择的解决方案
Pentalobe screw driver. Battery adhesive (I recommend using double sided tape instead).
这个答案有帮助吗?
得分 3
评论:
Hi, a mobile repair guy is doing this for me. He was just not able to source the body so I did that for him. So he must be having the screw driver. I'll order Battery Adhesives from eBay. Btw what are the disadvantages of using a double sided tape rather than battery adhesives (just asking)
完成的
There is none, just makes it easier to remove instead of using the original battery adhesive.
完成的
I'll have to use the adhesive only. Because in India the things double sided tapes are not available. Double sided tapes in India are very thick and hence it will not fit in the phone. Still thank you so much for answering
完成的
Thin double sided tapes**
完成的
添加一条评论
添加你的答案
Tommy Vercaty 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 3
总计 62
