跳转到主内容
修复你的物品
维修的权力
配件 & 工具
First generation of Apple iPad with 3G capabilities. Model Number A1337. Available with 16, 32, or 64 GB of storage. Repairs are straightforward and do not require heat.
89 个问题 查看全部
ipad...toss it in the trash?
I recently found an Ipad at work and after 30 days the owner didnt claim it. The passcode is impossible to decipher and each time I do it disables for longer periods between tries.
I can't restore through itunes.
What do I do...throw it out?
已回答! View the answer 我也有这个问题
这是一个好问题吗?
得分 0
评论:
Please Recycle Your Electronics. :)
完成的
添加一条评论
任天堂 Switch 套装
快速恢复到游戏的状态
购买 Switch 套装
任天堂 Switch 套装
快速恢复到游戏的状态
购买 Switch 套装
4个回答
已选择的解决方案
I don't think the USB port makes a difference. What does it say that makes you suggest that it needs the owners iTunes? BTW lucky find....
这个答案有帮助吗?
得分 3
评论:
http://www.ipadforums.net/ipad-help/6037... your issues are addressed here as well
完成的
holy shniekee that last link worked! try a few times because it didnt at first.
完成的
Glad I could help. Hope you enjoy your find. Remember to return and mark accepted the answer that best solves your problem. Best of luck to you :)
完成的
添加一条评论
No dont throw it out, what you do is connect it to a computer and have it open with itunes then you hold the power and the home button for a few seconds, afterwards it should say to connect to itunes thats going to wipe out the ipad completely and u should have a like new ipad
这个答案有帮助吗?
得分 2
添加一条评论
tried that...keeps wanting the original owners itunes. would it make a difference if I have 2.o USB port?
这个答案有帮助吗?
得分 0
添加一条评论
Put in DFU mode and restore
100% working solution
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
rob 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 1
总计 1,718
