does not come on.
my phone does not come on even when on charging.....the apple sign will come ON and off several times...but will never come on....
The phone switches off immediately when unplugging the cable while the apple logo is displayed correct?
Right now it is boot looping while plugged in.
If all these conditions are met then the battery is almost certainly faulty and needs to be replaced.
Otherwise the fault is most likely not the battery and is something else which means I may have to ask more questions to you to find out the most probable causes.
这个答案有帮助吗?
the battery was replaced very recently
If the apple logo turns off immediately after unplugging the lightning (charging) cable then I'm sorry to say the battery is most likely at fault.
Most probable cause: A bad battery unforunately.
Have you tried a restore through iTunes?
这个答案有帮助吗?
restore through itunes? why the phone doesn't come on?can you be more specific on the itune angle,please.
A media player by Apple Computer that is used for playing digital music or video files. iTunes is also used to purchase digital music files or subscribe to podcasts through Apple's iTunes Music Store. The iTunes player is also an interface on the iPod and iPhone.
This app can be installed on your computer, and your phone can then be plugged into your computer and it will interface with the app. When the app is installed and your phone is plugged in, hold down the power and home button at the same time and the app should pop up a menu asking you to restore the device you've plugged in.
I would definately try a second battery first, but give this a try of all else fails
thanks for your detailed explainations i will try what you have said and revert to you.god bless you.....
Happy to help, let me know if it helps
if the battery was replaced recently it may not have been plugged in to the socket fully
I just had the same problem whilst changing my battery pulled it apart again re connected the battery and all is good.
这个答案有帮助吗?
Another issue is that phones have a program that make that in some cases after 2 years it will break. In mine the battery after 2 years sutendly stop working :(
这个答案有帮助吗?
What program is that? Can you give us some documentation on it?
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 94
1条评论
Do you know what mode is your iPhone?
You can check it through iTunes.
由 Grace 完成的
