这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
4546 个问题 查看全部
iPhone 6 goes into boot mode
I purchased an iPhone 6 that had some water damage. The phone itself would continue to go through the boot loop and never actually restart.
The only way I could fix this is by unplugging the battery, plugging it into another device and charge for 30 seconds or so, then plug it back in and it goes through the loop and acts normally.
After that, the phone stayed on once until the battery died. Most of the time it goes back into boot loop once it goes into sleep mode and it always went into the loop upon restart.
I tried unplugging cameras, home button, and even replacing the wifi connector.
Any ideas?
已回答! View the answer 我也有这个问题
这是一个好问题吗?
按维修分数 0
评论:
Did you clean the board with isopropyl alcohol yet?
I did. The only thing that did was make the phone always be searching for a network.
添加一条评论
所有超过US$100.00或包含 Pro Tech工具包的订单免费送货!
浏览我们的商店
3个回答
已选择的解决方案
U2 Tristar charging ic gone bad and or battery too. Could be a bit of both from liquid damage.
这个答案有帮助吗?
按维修分数 3
评论:
Matt, just fully charge your battery in the other phone and then retry. If it works well until it's depleted then won't charge, as Ben say, its a U2 problem. If the battery doesn't take a full charge, then replace the battery and do the same test again.
添加一条评论
What do you mean boot mode? Apple logo on the homescreen?
If it is, that means your iPhone is disabled, you can restore your iPhone with 3uTools.
这个答案有帮助吗?
按维修分数 0
评论:
The phone comes on and stays on after I put the battery in it after I have it plugged into another phone. The phone shuts off when the screen goes completely black, then tries to restart. It gets to the very first Apple screen for about 5 seconds, shuts off completely, then tries again. Same thing over and over.
Could you please connect your iPhone to the PC, and launch iTunes or alternative tools to check what mode your iphone is in?
添加一条评论
Battery replacement might help
这个答案有帮助吗?
按维修分数 0
添加一条评论
添加你的答案
matt mocciola 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 113
