跳转到主内容
Dymo LabelManager 160 is fast, compact and lightweight, making it easy to label just about anything, anywhere. Type quickly on the computer-style QWERTY keyboard, edit with one-touch fast-formatting keys and print for perfect, professional labels every time.
14 个问题 查看全部
No charge no ink
My dymo keeps flashing low battery sign but I just changed the batteries also I have it plugged into the wall charger I believe this is also causing it to not print probably everything works like it should except there is no writing on the labels once they print out.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
4个答案
最有帮助的答案
MAGGIE , You could try another compatible charger as it may be faulty. Clean the battery contacts in machine using a pen with an eraser on he end as it is a little abrasive or a Qtip dampened with 90% Isopropyl Alcohol or better, clean the terminals well and then blow out the dust/debri and change the batteries out for some new good quality batteries and try. Good luck.
这个答案有帮助吗?
得分 4
添加一条评论
In case someone else googles this like I did. I figured it out shortly after. My colleague had inserted a couple of the new batteries the wrong way. Check the direction of the batteries and it should fix this problem.
这个答案有帮助吗?
得分 0
添加一条评论
I had the same problem. I rechecked how I installed the batteries and sure enough 2 of them were put in the wrong way. Corrected this and labels are printing correctly now.
这个答案有帮助吗?
得分 0
添加一条评论
On mine I have checked the batterys a few times but it still won’t print, the machine is brand new but there is no ink, the baterys are new and good
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
MAGGIE 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 19
过去 30 天: 48
总计 6,462
