跳转到主内容
在与惠普合并前,康柏电脑制造全系列的笔记本电脑。 现在他们由惠普制造,拥有最基础功能的电脑。
What can I do to fix my video card?
My computer first started acting up after I downloaded an update for a game. The game then caused me to randomly have bsod which did not provide me any error code. My monitor has started cutting out every once in a while now and the entire screen shows a random color. To reverse this I have to put the computer into standby mode and reactivate it. I appreciate any help you can offer.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
1条评论
My computer is a Compaq Presario V6000 with an intel integrated chip set.
完成的
添加一条评论
6个答案
已选择的解决方案
You can try to reflow the GPU chip it is fairly easy if you know what you are doing. A more permanent solution would be to re-ball the soldering on the GPU chip you can youtube it so you can get an idea of how to do it but the tools needed would probably cost more than a new laptop. I have fixed this problem on numerous laptops by just doing a reflow so that is probably what I would do. Good luck!!
这个答案有帮助吗?
得分 3
添加一条评论
Go here and see if your machine has the Nvidia issue: http://www.nvidiasettlement.com/affected...
这个答案有帮助吗?
得分 2
1条评论:
My computer wasn't on the list. It has an Intel integrated chip set.
完成的
添加一条评论
How to fix video problem on HP laptops
这个答案有帮助吗?
得分 1
添加一条评论
Kiba32b, you might want to check here will not power on about how to reflow and fix the issues that might be causing your problems. Good luck
这个答案有帮助吗?
得分 1
添加一条评论
Hi,
Compaq Presario V6000 are known for a big hardware problems with the GPU and the Mainboard.
I have one, my laptop still have a black screen when booting... nothing on the screen.
So I took the mainboard, remove CPU, RAM, and remove any plastic item ( eveything you know it can melt )... And put the mainboard in the oven ( at 160°C ) for 3 minutes.
When 3 min past, be careful, handle the mainboard carefully. Put in on your table.
Wait until the mainboard is cool.
Replace the mainboard carefully.
=> Test
这个答案有帮助吗?
得分 0
添加一条评论
I have this game and sometimes when I start to play it,the game freezes on me.Would this be a problem with the graphic card or would it be something else.??
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Kiba32b 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 25
总计 13,126
